Repair Component On Asus x51rl Motherboard
Posted: Wed Apr 24, 2013 11:41 am
by GazzaS
New to this forum so hi all.
Basically our family laptop (Asus x51rl) died a death due to a faulty power supply. I could smell burnt silicon from inside it and dismantled it to find the issue.
I've found the source of the issue which is a burnt component by the battery socket which must be some sort of shorting pin. I've fixed computers all my working life and build electronics for a hobby but have never had a go at fixing integrated circuits before. Hell, what have I got to lose ;)
Can anyone identify the component that is burnt out, I've attached two images of the damaged board and a couple of images I found on the net of the same board area with no damage.
Damaged Motherboard
Damaged Motherboard
Damaged Motherboard Area
Undamaged Motherboard Area
Thanks for any advice,
Gary
Re: Repair Component On Asus x51rl Motherboard
Posted: Thu Apr 25, 2013 9:49 am
by GazzaS
Found some more information. After a lot of searching (mainly non-english sites with google translate) I have found a few more images:
According to the forums it is a 5 volt Regulator part of the 5 volt stabilizer circuit labelled PU5900. The actual chip has marking 8C752 and they call the chip Stabilizator (but this could be a bad translation). They also mentioned replacing it with L78L05ACUTR.
Does this seem right from the new images? Would replacing the chip with the L78L05ACUTR be ok?
Thanks again,
Gary
Posted: Thu Apr 25, 2013 10:42 pm
by Biffo
You now have to ask the question
did it die or was it killed?
