electromagnetic field sensor-help please
Posted: Sat May 18, 2013 9:20 am
by Susan
Hello everyone,
I am trying to build a circuit which consists of an equivalent circuit for a monopole antenna and a voltage doubler. I would like to detect the el-mag field from 100 MHz up to 10 GHz. But as a start, I can smooth the goal to 4-5 GHz.
This equivalent circuit for the antenna is valid up to 3.5 GHz approx and the frequency response is not flat in frequency.
antenna equivalent circuit + detector (bat17 diode model)
Would you please tell me the best way to proceed with the circuit, in order to have a reasonably flat response and further proceed with some voltage doubler maybe?? Did i do something wrong with my circuit?
antenna equivalent circuit+voltage doubler
I attach a circuit which I simulated with ADS as well as SiMetrix. The first part of the circuit is just the equivalent circuit for this antenna, the rlc parallel in series with the loss resistance and the capacitor.
Right now I have been trying with just a sinusoidal source, to further move to some impulsive sources maybe.
Thanks in advance to anyone might help me :)
Re: electromagnetic field sensor-help please
Posted: Fri May 31, 2013 4:45 pm
Hi, where did you get this circuit... it seems totaly irrational.
The RLC bit will filter out, not in... but that is if the rest made any sense... may be I am a bit thick but I cannot make head nor tail of that.
Posted: Sat Jun 01, 2013 2:00 pm
Come back on this, I just dont know... may be Mick Faraday could shed some light.
Tar&stuff
