Repair Component On Asus x51rl Motherboard
GazzaS
Post by GazzaS » Wed Apr 24, 2013 11:41 am
New to this forum so hi all.
Basically our family laptop (Asus x51rl) died a death due to a faulty power supply. I could smell burnt silicon from inside it and dismantled it to find the issue.
I've found the source of the issue which is a burnt component by the battery socket which must be some sort of shorting pin. I've fixed computers all my working life and build electronics for a hobby but have never had a go at fixing integrated circuits before. Hell, what have I got to lose ;)
Can anyone identify the component that is burnt out, I've attached two images of the damaged board and a couple of images I found on the net of the same board area with no damage.
Damaged Motherboard
Damaged Motherboard
Damaged Motherboard Area
Undamaged Motherboard Area
Thanks for any advice,
Gary
GazzaS
Re: Repair Component On Asus x51rl Motherboard
Post by GazzaS » Thu Apr 25, 2013 9:49 am
Found some more information. After a lot of searching (mainly non-english sites with google translate) I have found a few more images:
According to the forums it is a 5 volt Regulator part of the 5 volt stabilizer circuit labelled PU5900. The actual chip has marking 8C752 and they call the chip Stabilizator (but this could be a bad translation). They also mentioned replacing it with L78L05ACUTR.
Does this seem right from the new images? Would replacing the chip with the L78L05ACUTR be ok?
Thanks again,
Gary
Biffo
Post by Biffo » Thu Apr 25, 2013 10:42 pm
You now have to ask the question
did it die or was it killed?
