Help me identify this component?
Darrenshan
Can anyone help me ID this component, please? and if possible where I can buy 1 (or 10!)
The item, as best that I can describe, is a switch actuator or housing for a micro switch.
The actuator is fastened to a desk and inside the desk, the micro switch sits inside the actuator so when the actuator is pressed, it presses the microswitch.
The key thing here is that I can remove the micro switch, complete with the associated equipment and leave the actuator in place, bolted to the desk.
I obviously could just fit a normal SPST switch to the desk but then I would have to unsolder the wires to the switch, or fit spade connectors and pull them off when I wanted to remove the equipment.
- Attachments
- 2017-01-05 15.18.51.jpg (43.97 KiB) Viewed 6100 times
- 2017-01-05 15.18.33.jpg (69.71 KiB) Viewed 6100 times
- 2017-01-05 15.18.25.jpg (89.32 KiB) Viewed 6100 times
Re: Help me identify this component?
Hmmm ... I must say that I haven't come across anything just like this with a detachable microswitch. Presumably the actuator has to be fixed on the desktop? Could you use for example a reed switch inside with a bar magnet on top of the desk?
Google is the go-to place for out of the way things. Try searching for "key operated microswitches" - you may something to assist amidst the millions there are to choose from!
