Electrical cct
Shaggy1505
Electrical cct
Post by Shaggy1505 » Mon May 07, 2018 9:00 pm
Hi I have built the cct shown below I have modified it slightly by including a 10v motor, on/off push button switch and 2 9v batteries as the power source. The problem I have is after a few seconds of operation the batteries get extremely hot, I am unsure what to do to prevent this from happening. I would really appreciate any help/advice.
Re: Electrical cct
Post by David » Tue May 08, 2018 2:16 pm
Hot batteries mean that an excessive current is being drawn by something in the circuit. Do you have a meter capable of reading volts and amps? Have you checked the built circuit against the schematic? Do any other components get hot? Crucially - what sort of motor are you trying to operate? Are you using the small PP3-type batteries?
Replace the motor with a 1K resistor and see if the batteries still get hot.
It would be of use to see a pic of the batteries and the motor.
MichaelBo
Re: Electrical cct
Post by MichaelBo » Sat May 12, 2018 12:03 pm
Hi David, could it mean that the batteries are malfunctioning as well? The schematic checks out from what I gathered. I'm just thinking out loud, really.
Re: Electrical cct
Post by David » Thu May 17, 2018 8:46 am
The batteries may well have been damaged by excessive current drain and heating. If you want any more assistance, please post the answers to my questions in the earlier reply.
