Fire Fly drawing
spike1947
Fire Fly drawing
Post by spike1947 » Sun Mar 06, 2016 1:45 pm
I am attaching a drawing for a flickering LED solar charged , I am wanting to change the supply voltage to 2.4v ( from 2 x 1.2v Ni-MH ) and using 2 x solar panels from the pound shop ( giving out 5.6v ! ) , driving a flickering LED 1.8v to 2.2v .
What would I have to change to obtain my result ! .
cheers
spike
Sock Puppet
Re: Fire Fly drawing
Post by Sock Puppet » Sun Mar 06, 2016 5:05 pm
Looks like it's been done (half way down this webpage) : http://www.evilmadscientist.com/2008/si ... -circuits/
A Schottky diode would work well in there.
computer blind
Post by computer blind » Mon Mar 21, 2016 2:25 am
whats the point in the diode, it seems to serve no function to me.
Post by David » Tue Mar 22, 2016 12:06 pm
The diode is essential. In the day, the solar cells charge the battery through the forward-biased diode. The PNP transistor's base is positive to its emitter, and the transistor is cut off. At night, the voltage of the solar cells falls below the battery voltage, and the voltage on the transistor's base drops towards zero also. The diode is reverse-biased, and the emitter voltage is held up by the battery. The transistor turns on, thus lighting the LED.
computer blind
Post by computer blind » Fri Mar 25, 2016 10:18 am
wait. i see. its to stop the battery going to the base of the transistor.
