RE: RADIO NOISE CANCELER stuck on 1 problem
cobra148
Post by cobra148 » Fri Apr 15, 2011 1:35 am
Could some kind soul look at the attached layout and schematic, and tell me if I have the wiring to a sliding change over switch correct.
The wiring I need help on is from the 3 toroids to the change over switch S2 (switch only has 6 solder tags).
If some one could look at the schematic and follow the connections to the switch.
Also is the wiring correct on the S1 switch ?.
This is all I am not sure about.
Thanks in advance for any help offered.
2 SCHEMATIC.png (65.67 KiB) Viewed 3573 times
1 LAYOUT.png (158.52 KiB) Viewed 3573 times
