mod 60 counter with start/stop and reset button
NewGeek
Post by NewGeek » Wed Dec 21, 2011 12:12 pm
I need help in this. The circuit is done using a Multisim file. When S is pressed, it will start to count from 00 to 59. When S is pressed again, it will pause the counting while R will reset it to 00. Problem is why the counter cannot count again after reaching 00 and I must press S to start it again? Is there any modification or additional logic gates to be added? :?
mod 60 counter.jpg (42.23 KiB) Viewed 11724 times
User avatar
Thomas W
Re: mod 60 counter with start/stop and reset button
Post by Thomas W » Wed Jan 11, 2012 1:49 pm
What does the text say on the pins of 74LS93N?
NewGeek
Post by NewGeek » Thu Jan 12, 2012 3:07 pm
Here is where each pins are connected on the 74ls93.
Pin 1- CP1
Pin 2- Master Reset
Pin 3- Master Reset
Pin 5- VCC
Pin 8- Q2
Pin 9- Q1
Pin 10- Ground
Pin 11- Q3
Pin 12- Q0
Pin 14- CP0
Pins 4,6,7 and 13 are not connected.
User avatar
Thomas W
Post by Thomas W » Sun Jan 15, 2012 12:15 pm
I would like to see a zoomed in version of the schematic, so that the text on the 74LS93N is readable?
spnrajan
Post by spnrajan » Wed Jun 12, 2013 2:11 pm
NewGeek wrote:I need help in this. The circuit is done using a Multisim file. When S is pressed, it will start to count from 00 to 59. When S is pressed again, it will pause the counting while R will reset it to 00. Problem is why the counter cannot count again after reaching 00 and I must press S to start it again? Is there any modification or additional logic gates to be added? :?
Post by piratepaul » Wed Jun 12, 2013 5:28 pm
Off the top of my head, I have not looked up the numbers... surely 00 must have a logic, so if you include another chip which outputs a 1 when and only when its input is that logic and feed it back to S ... it will work... hmmm off the top[ of my head!.
